Tim - There should be 2 fuel strainers that require attention:
1 - The sediment bowl strainer. It's a round screen fitted between the glass bowl and the gasket. (Sometimes this screen goes missing...)
2 - The carburetor inlet strainer. This is small tubular screen attached to the backside of the fuel inlet nut. It can be removed by disconnecting the fuel line at the carb then unscrewing the large hex fitting (the fuel inlet nut) behind it.
After cleaning both screens and before reconnecting the fuel line, suggest draining a cup or two of fuel thru the open fuel line to flush out any rust, etc. that might be in the line. Also if you can get the drain plug out from the bottom of the carb bowl, remove it, turn the gas on and let a cup or two of fuel flush thru the bowl then replace the plug.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
