Posted by rustyfarmall on October 28, 2010 at 07:58:35 from (209.152.78.140):
In Reply to: Brush Guard for M ? posted by Melvin Ware on October 28, 2010 at 07:35:33:
The grill insert has a "wing" on the backside. You loosen a screw, position the wing so the insert can be put in place, then put that wing into a vertical position and tighten up the screw from the front. Many of these were lost because either the screw was not made tight enough, or it just palin loosened on its' own accord and the insert just fell out where it was then ran over by the tractor and destroyed.
If being correct is not an issue, just find a piece of window screen and wire it on over that opening.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
