Bud, the easiest thing to do is pull the oil level plug on the side and fill it. Then make you a dip stick with a tape measure, dowel rod, stick or whatever. Run it all the way to the bottom of the tranny. Mark the oil level. You never have to pull the side plug again. If you have drained it or it is low, you can add a quart/gallon at a time and make a mark. Besides the seal the tranny has a habit of leaking and allowing the hydraulic pump to suck air. The cure is to overfill it by 5 gallons. Doesn't hurt to overfill it by that much. Done all the time by people here.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
