Posted by Wardner on November 03, 2010 at 21:22:00 from (4.154.235.193):
In Reply to: 650 IH posted by plow hand on November 03, 2010 at 19:44:15:
It could be as simple as water in the carb. It is equally as simple to drain it off through the carb petcock. You will also have to clean the starting tank sediment bowl. I mention this because it happened to me the other day. Don't know where the water came from but it must have been in the five gallon gasoline bucket.
Standard gas engine troubleshooting procedures apply here. Check fuel and spark. You can get a rough idea of the gas side compression by comparing the cranking speeds while in gas or Diesel mode.
A 650D in good condition will start on Diesel with the starter if starting fluid is used. Don't think anyone would recommend that method as a regular procedure. They will also start on Diesel if hot. A high watt block heater might be hot enough.
I have never had to mess around the with the multiple linkages, valves, or switches on any of the three gas-starts I have owned.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
