Posted by rustyfarmall on November 05, 2010 at 07:21:08 from (209.152.78.140):
In Reply to: start-up posted by JKYR on November 05, 2010 at 06:48:25:
You should remove the spark plugs and squirt generous amounts of automatic transmission fluid into the cylinders before you ever attempt to crank the engine. Wouldn't hurt to change the engine oil and replace the filter. Also would be a very good idea to remove the carburetor, dis-assemble, and give it a good look over and at least a quick cleaning, likewise with the fuel tank and fuel sediment bowl.
On the ignition side of it, at least remove the distributor cap, inspect it, and while it is off, take a look at the contact points. If they look OK, drag a piece of paper between the contacts to clean them up a bit. If the points look worn and corroded, replace them.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
