Problem is gas problems act like electric problems cause it dies so quick like someone turned a switch. These tractors are gravity feed and don't have a fuel pump like a car that lets it sputter along for a while.
I think those resistors may get hot but it sure doesn't hurt to get the 12v correct coil from NAPA that states on it that it has internal resistance. According the the expertts here and in the archives, the winding inside does the resistance or something like that. Coils are just under $20.
When it dies immediately check for spark. Then you know if it is the coil or something electrical. Coils when they go bad will get hot they say. Mine never did but I replaced it anyway. It was a new to me tractor and I had no idea how old anything was except by the paint and rust on everything. It had a lot of farmer rigging done to it for sure. Coils, points, condensers, and batteries are cheap compared to all the frustration for being shut down.
I figured out they had rust problems before as they had ditched the sediment bowl and put one of those inline filters in. It did and they eventually do fill up with rust. And they won't handle flow at a peak time. No way you can have an inline filter in their and run it hard. I said idling earlier but they will run fast for a while till the rust particles begin plugging it up and restricts the flow till the carb runs dry and it quits. Then it sits for a time while you are wondering what is happening and during this while enough gas trickles into the carb so it starts and runs for a while. Kind of a viscious cycle. They you have to pick a way to fix it. Seems like I acidize the tank and soak the carb in Berrymans and blow out the passages at the beginning of each summer. Had some screen stuck up the tank intake a couple inches and it plugged off. This summer I did as Allen said and used a piece of rubber hose stuck up an inch and a half to stop rust particles.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
