Sawtooth throttle controls are actually relatively easy to repair if you have access to a welder or can weld yourself. Run a heavy bead of weld along the worn teeth and on the single tooth on the handle.
Rough shape with weld with a bench grinder on both parts. Use a mill file to recut the notches into the throttle plate and the handle. I did one last year, took me about 3 hours to weld, grind, and file.
With a coat of paint on, you wouldn't know that it had been redone.
One last hint, I put a slight twist/bend in the handle so that the "tooth" in the handle engages the plate more agressively. Imagine a right triangle with the veritcal side to the right. both vertical surfaces (plate and handle) should be exactly parallel when they make contact. That is the slight bend that you may have to put in the handle.
as always, IMHO.
This post was edited by Tom Fleming at 01:52:15 11/12/10.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
