The Voltage regulator adjusts the generator output to limit the charge rate according to the needs of the battery, and lights/electrical loads. It maintains a 7 to 7.2 volt charge rate and will top off the battery, and not over charge it. It also contains a cutout relay that is the same as a stand alone cutout relay. A generator in operation has an almost direct link to the battery negative and to ground on its frame. As long as it generates more volts than the battery it is happy. If the idle is low, or lights are on at low speeds, or the engine is off, the generator would be a direct connection to ground and thus in short order it would overheat and burn up. It would draw as much or more than it can produce. It is thus necessary to disconnect it as soon as its voltage is less than the bat voltage. The cutout does this, preventing excess discharge. The voltage regulator sees gen output, and varies the F terminal path to ground. From full ground max output, to just keeping up with a light demand, it senses the needed voltage, and grounds the F terminal appropriately. This grounding (on this A type system) is the only way the field is energized, it is fed voltage inside from the third brush, or from the Arm terminal to get its power source. Jim
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
