Most Dealers probably didn't have torque wrenches when these were built.
Only one big nut on the flywheel of the 20, bigger than the one on the front of the crank. Tighten as tight as possible and then bend the locking washer to lock it. This sets the position of the rear crank bearing, then tighten the front nut on the crank and your set. The front bearing can move fore and aft in its holder the rear is held by a lip. Rod torque is kinda difficult with castle nuts that are secured with cotter pins. You will have to torque and then check if the cotter lines up, if not then tighten more to line up the next slot. There is no torque for the mains, they are ball bearings in cages held together in alignment by the big nuts on the crank and flywheel.
This post was edited by 36F30 at 15:22:54 11/17/10.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
