Re: Best way to time a farmall H?
Posted by Shawn in PA on November 18, 2010 at 18:03:31 from (24.154.38.87):
In Reply to: Best way to time a farmall H? posted by Hunter Burnett on November 18, 2010 at 16:16:11:
Static time it...Bring #1 up to tdc. There should be 3 total marks on the front pulley. Two are very close together, and another mark is off on its own. Ignore the one off on its own. It's for greasing the pilot bearing. Line the timing pointer up with the second of the two marks that are close together. Point your rotor so it's firing at #1 on the dist cap. Put your cap back on, and leave your dist loose. Turn on the ignition switch. Take a test light and hook one end to ground and one end to the terminal on the of the side of the distributor. Turn your dist body in the direction of the rotor rotation so that the test light just blinks out. Now turn the rotor body in the opposite direction, against the rotor rotation, to where the test light just blinks on. Lock down the distributor...Static timed. Assuming your points are in good working condition and set properly. Shawn
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
