Re: My New Alternator Just Quit Charging All of a Sudden!!!
Posted by Owen Aaland on November 20, 2010 at 02:02:57 from (198.70.47.156):
In Reply to: My New Alternator Just Quit Charging All of a Sudden!!! posted by robgIN on November 19, 2010 at 19:36:22:
The way you have it wired the light serves two purposes. One is to provide power to excite the regulator so that the alternator will begin to charge. The other is to provide an indication of the system working when the light goes out. With the light not working the alternator never starts to charge.
Normally manufacturers would use a light along with a resistor so if the bulb burned out the resistor could provide the power to the alternator for it to begin to charge. On systems with lights for both oil pressure and charge indicator you will often notice that the charge indicator bulb does not burn quite as bright as the oil pressure indicator bulb when the switch is on with the engine off. The resistor in the indicator light assembly is the reason for the difference.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
