Posted by Owen Aaland on November 25, 2010 at 22:14:45 from (65.165.246.145):
In Reply to: 706 Reverse problem posted by kennell on November 25, 2010 at 19:34:02:
If it shifts into high range and low range like it should then most likely the problem is under the cover and not linkage adjustment.
Likely causes are a broken/missing roller on the reverse arm or too much play where the arm pivots in the cover. Less likely causes are a broken reverse shift fork or broken thrust washers on the reverse idler shaft.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
