You can turn the rims around to get more clearance but the tractor will suffer for it. It causes harder steering and can lead to broken spindles.
If you follow the center line of the spindle down to the ground you will find that it meets the ground about the middle of where the tire contacts the ground. That allows the wheel to pivot on that spot when the wheels are turned. If you reverse the rims the center line of the spindle will not be in the center of the tire. When the wheels are turned they can no longer just pivot but must also roll. This increases the effort needed to steer.
Also by moving the wheels out away from the center line it changes the forces on the wheel bearings. As originally designed most of the load is carried on the larger inside bearing. With the wheel moved out the load moves more to the smaller, outside bearing. This makes the horizontal part of the spindle act like a lever and greatly increases the forces on the angle of the spindle. This can lead to spindles breaking at the inner end of the large bearing.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
