Posted by Owen Aaland on December 02, 2010 at 14:01:44 from (65.165.246.162):
In Reply to: IH 460 issues posted by Janicholson on December 02, 2010 at 09:16:50:
What style of PTO do you have? Early tractors had a planetary type. That unit has a small oval cover on top and the engagement lever will latch in both the engaged and brake position. The later tractors had the over center clutch style where the handle will latch only in the brake position.
The later, over center type, is more likely to see this problem. If the bolt that clamps the lever to shaft going into the PTO unit is not tight enough the woodruff key in the shaft can shear off and you will not be able to shift it. If the linkage moves going into the unit itself you may have mechanical problems that will need disassembly to repair.
Today's Featured Article - Third Brush Generators - by Chris Pratt. While I love straightening sheet metal, cleaning, and painting old tractors, I use every excuse to avoid working on the on the electrics. I find the whole process sheer mystery. I have picked up and attempted to read every auto and farm electrics book with no improvement in the situation. They all seem to start with a chapter entitled "Theory of Electricity". After a few paragraphs I usually close the book and go back to banging out dents. A good friend and I were recently discussing our tractor electrical systems when he stated "I figure it all comes back to applying Ohms Law". At this point
... [Read Article]
Latest Ad:
[More Ads]
