Posted by WSJ on December 05, 2010 at 11:54:30 from (216.139.17.182):
If you have the space to mount a 6 Volt golf cart battery, a $5 core could last for years on your tractor. When a golf cart can’t make it through the day without stranding the golfer, the pack is replaced. I have replaced many cart battery packs and found there is usually one bad battery and the rest are fine to use on my tractor. This is possible because the batteries in a golf cart are connected in series and the weakest battery in the pack limits the range of the cart.
The reason a golf cart battery core can be used on a tractor is the requirement to start a tractor is much different than powering a golf cart. If a tractor can start in about 10 seconds with a battery current of 100 amps, the Amp hours used are 100 times 10 divided by 3600 (seconds in an hour). This is less than 0.3 Amp hours. I have measured golf cart battery cores at more 50 amp hours. A new 6 Volt tractor battery is about 50 AH and a useable battery can be less than 10 AH. I have started engines on a battery with less than 5 AH.
A quick way to choose which core to buy is finding the battery with the highest voltage in the same pack. If they all were charged and discharged together the best battery will have the highest voltage. It may take a day or two to charge the battery before it’s ready for your tractor.
Wayne
This a discharge curve of an old 6 Volt battery logged with a BATTERY TEST SYSTEM I designed several years ago.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
