Posted by Janicholson on December 05, 2010 at 12:53:43 from (67.72.98.45):
In Reply to: H distributer posted by JKH on December 05, 2010 at 10:05:36:
All distributor from Hs and Super Hs will bolt right on where the Mag is now. Almost all 4 cylinder IH distributors will also work if you change the centrifugal advance springs, and advance stop limit. They will work without changes, but the total advance and curve will be off. The ignition switch will need to be changed (the current switch is a grounding "kill" switch). A new wire from the load side of the Amp meter will be the source of voltage to the switch, and from the switch to the coil negative side. (positive ground system. Jim
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
