Posted by Owen Aaland on December 09, 2010 at 17:34:57 from (65.165.246.162):
In Reply to: 766 water problem posted by kennell on December 09, 2010 at 15:41:53:
HyTran is designed to absorb up to 3 percent water and keep it in suspension. That keeps the moisture from collecting on gears and bearings and causing them to rust. the downside is that in sub freezing temperatures this water will freeze to form ice crystals that will not go through the filter or bypass screen. Since the water stays suspended in the oil you can't just drain it off the bottom to separate it.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
