With respect, I disagree with one of your statements. I believe the percentage of time the points are open or closed is the same at all speeds (until point bounce/flutter happens at some 5000 rpm (unlikely with a Farmall for very long) The dwell is constant. The time the points are closed is longer at low speeds, but so is the time they are open. Thus the duty cycle is identical at starting and operating speeds, and is the ratio of open to closed.
The ignition needs to work harder (produce higher firing voltage) at idle than at high speed and load conditions. A partial vacuum 20"of HG is harder to fire a spark through than compressed air and fuel at 140psi. Looking at an ignition scope under variable throttle/load/speed conditions will illustrate this with clarity.
Cold resistors do pass more current than hot resistors do, but the load from operation is basically the same on the primary due to the slow speeds of these engines allowing the coil to have optimum saturation, and continuous "duty cycle". On 1/3 off 2/3 only gets into overheating if the on is 10 minutes, and off is 20 minutes. Even then it would probably cool enough in 20 minutes to avoid damage. (exaggerated for emphasis) Jim
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
