"but as compression increases doesn't the amount of spark have to increase to ignite the fuel/air mixture as well as in increasing the gap?"
ANSWER: You would have to define "amount of spark"????? What is true is that as compression increases, the VOLTAGE across the spark plug gap has to rise higher BEFORE it fires its spark (which ignites the fuel)
Then you state: with a stronger coil you can increase the gap and get more fire in your cylinder as well.
ANSWER If the gap is increased (just like if compression is raised, read the articles in my post) that likewise increases the voltage necessary for the plug to fire. YES its true some after market so called "high voltage" coils have the capacity/ability to achieve higher voltage (as may required in high compression racing engines) buttttttttt regardless of HV or stock coil, the voltage only rises high enough to fire the plug so the HV coil wont fire at any higher voltage then the stock coil. ITS JUST THAT IF COMPRESSION IS HIGH OR GAP REAL WIDE (read my articles) THE HV COIL HAS THE ABILITY TO ACHIEVE THE NECESARY HIGHER VOLTAGE...
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
