Thank you to everyone who took the time to post a reply and make suggestions, I really appreciate that you are trying to help. I wanted to clear up this issue with respect to the bolt and specifically the washer that holds the gear on the end of that shaft. The washer and bolt are indeed tight and in place. I actually had lots of trouble with it this summer. The washer is actually a thick washer(about 1/8 to 3/16 thick) and is recessed(about 1/16") so it can go over the shaft slightly and the shoulder then keeps the gear tighter onto the splined shaft. I have fixed this issue early this summer and believe it is not the cause of the current issue. I have pulled the inspection plug and made sure the bolt is still tight, and also removed the pump mounting plate so I can visually see that everything is ok in this area and this is how I noticed that the Large gear that drives the hydraulic pump and the small gear above it are not aligned. So I dont confuse things I will leave it at that. This post was in response of the replies about the washer and bolt issue. Thanks again everyone for all your help. Tod Michigan
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
