Re: Need 400 help won't start in cold weather
Posted by mkirsch on December 15, 2010 at 10:10:43 from (64.80.108.56):
In Reply to: Need 400 help won't start in cold weather posted by Denis in MI on December 15, 2010 at 06:25:08:
You shouldn't need to resort to crude gimmicks to get the tractor to start.
First off the tractor will start better closer to idle than wide open. You're shooting yourself in the foot with that regard.
Try giving the tractor a little bit of throttle, 1/3 at most, and blipping the choke to see if it will fire.
Every tractor is a little bit different, and you need to feel out what it wants to make it run. Some you need to set the choke and leave it there until it's warmed up a little. Some just need a quick blip of choke to get it to fire, then a couple more blips to keep it running for the first 15 seconds.
I'd buy the weak spark argument if the problem started in bitter cold, but at 40 degrees the battery isn't weakened much if at all.
Part of the problem with "hard starting" tractors are people used to computer fuel injected cars where you just turn the key and go.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
