Many people, like you, report improved starting and idling and for sure the solid state switch technology is a great improvement over mechanical eventually burning bouncing pitting carboned resistive points SO LONG AS ITS WORKING !!!!!!!
But if it quits youre screwed versus if the points get burned a cleaning n filing can get you back to the barn.
I always advise people to get the most bang for the buck and to utilize all the advantage the elec switch has to offer (over points) that it be properly matched with a high energy coil to yield a higher energy spark. If a body wants (NOT a requirement, the above is fine and helps) they can also use a High Voltage coil and run a wider plug gap butttttttttt be sure the plug wires and cap n rotor etc are all in top shape because youre then operating at higher voltages more susceptible to HV breakdown insualtion failures !!! One can still use a higher energy coil then the stock coil at the regular plug gap to still discharge more spark gap energy then with the total stock system mind you (its NOT necessary to widen the plugs gap)
Its NOT a cure all for a worn out engine or one thats way out of time or has fuel issues etc and dont gain one much if any HP BUT AS LONG AS IT WORKS it can (if matched with right coil) produce more spark energy and can give good starts and idle
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
