Posted by John T on December 16, 2010 at 09:39:20 from (66.244.97.31):
In Reply to: Jumping 6v? posted by Faster346 on December 16, 2010 at 07:45:59:
ALWAYS JUMP POS TO POS AND NEG TO NEG
Regardless which battery post happens to be bonded to some huge hunk of iron lol
I DO NOT recommend jumping a 6 volt battery direct with a 12 volt battery, it can blow up !!!!!!!!!!!!!!!!
If I need to jump start a 6 volt tractor with 12 volts, I JUMP THE STARTER MOTOR ONLY. This can be done iffffffffff the starter motor has an exposed available connection post,,,,,,,,,Or if you can get to the output (Starter NOT to battery) side of a starter switch or starter solenoid.
This is a high current connection and can cause big time sparks USE CAUTION and DO NOT allow sparks anywhere near the battery. I prefer the last jump connection be made somewhere on a clean non painted part of the frame/chassis AWAY from the battery. Use good quality jumper cables with strong clamps
REMEMBER POS TO POS NEG TO NEG
If a tractor is Pos ground, that means its battery POS is tied to frame/chassis so thats where the POS of the jump cable is (or can be) attached as its wired to the batterys POS post i.e. youre still jumping POS to POS
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
