Posted by JoeVT on December 16, 2010 at 12:18:25 from (208.65.161.84):
A while ago I posted seeking advice on rebuilding the governor on my SA. Thanks for the advice. I have wound up rebuilding most of it. In the housing, the bumper spring was shot and replaced, the spring lever had an 1/8" divot worn in the top from hitting the high speed adjustment, the spring had worn a groove in the hole on the lever (I jb welded these), replaced the rockshaft that was badly rusted, pitted and scored (from the failed needle bearings), replaced the needle bearings and replaced the governor spring (installed it as per the service manual pointing the right way). I did not bush out the input shaft, that was the only thing that seemed OK. On the drive gear the thrust bearing was badly worn and replaced. The thrust pin was frozen in place. With heat and penetrating oil, I was able to remove it and and replaced the thrust spring and pin. Before I removed the gear, I marked the teeth so it was installed in the same location.
Now, upon reinstallation and sync'ing the rockshaft with the carburetor the rock shaft arm hits the alternator belt when going toward idle. Any guidance on where I have gone wrong would be appreciated. Thanks.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
