If you do the conversion , do not get the coil that does not need the ballast resister(3 ohm coil). Get the 1.3 ohm 12volt coil and the proper ballast resister with it. Use the existing (or install) starting bypass wire so that you will get full voltage to the coil when starting.
The 3 ohm coils have a high resistance wire in it to increase the resistance to 3 ohms. The winding ratio is unchanged from the 1.3 ohm coil. As this coil has no way to bypass this additional resistance when starting , when cold the tractor will be much harder to start.
Also the heat generated by the ballast resister will now be generated inside the coil increasing resistance and shorting the life of the coil.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
