No argument from me. A self-contained magneto with a working spring-loaded impulse does not rely on good cranking speed to make good spark. A tractor with a battery ignition does, and a 6 volt system is apt to have worse spark when cold-cranking, then a properly designed 12 volt system. In fact, even some new cars with "high tech" electronic, high-energy igntions will not fire at all when cranking voltage drops below 9 volts.
One drawback to self-contained magnetos is that most are limited to 15,000-20,000 volts of max spark energy. Some older machines at times need more, and some do not. A good 12 volt battery igniton typically can make 30,000 - 40,000 volts. Your statements rely on tractors being in "perfect" tune. I suspect many are not, though. Having extra spark energy with fouled spark plugs can often make the difference of a running tractor - versus a non-running tractor.
And with generators versus rectified alternators? There is no comparison when it comes to output and efficiency. An alternator is far superior. All depends if somebody actually needs it or not. I'm sure many old tractors don't.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
