bc you have a 2606, right? haven't you posted about having a messed up electrical system? I would definitely try to make that right!
if your tractor is the same as a 656 in factory form (my reference is a 72 model), there is supposed to be a resistive wire coming from the ignition switch to the R terminal of the starter. from the R terminal, a regular wire goes to the coil. When the key is on, the resisive wire feeds the coil at reduced voltage, and the R terminal is electrically dead to/from the starter assembly and serves only as a junction block. When the starter button is depressed, the R terminal is energised with the starter, and the coil gets fed a full 12 volts as best as the electrical system can supply with the starter load. Even if the resistive wire was eliminated and a regular coil used, the R terminal still helps with starting because the distance the current must travel to the coil is halved and the loads shared with the ignition circuit are eliminated.
So maybe the charger would help your ignition circuit when starting but those are awful big clamps that could be accident/spark prone with the smaller wires you'd be trying to connect to. My vote is fix the electrical system :) and over-duty the lighting system with redundant grounds and relays for anything more than 2 35watt headlights and a red tail light.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
