Re: light switch
Posted by rustyfarmall on December 18, 2010 at 12:54:59 from (209.152.78.140):
In Reply to: light switch posted by Blackstack on December 18, 2010 at 11:07:50:
The 4 position switch was used with the cut-out relay which did not automatically regulate how much charge was being put into the battery, so if you were using the lights, the high charge position was used, and if using the tractor WITHOUT the lights, the low charge position was selected to prevent overcharging the battery and boiling it dry. I sometimes use the high charge position on my 1940 H if I will be running the tractor for only a short time, because it will more quickly replace what is lost in the battery from just starting, but the low charge position is always used when using the tractor for an extended period. The ampmeter is a good indicator of which setting to use.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
