Re: 826 German main bearings
Posted by Owen Aaland on December 19, 2010 at 17:49:10 from (198.70.47.181):
In Reply to: 826 German main bearings posted by ihjasonj on December 19, 2010 at 09:13:50:
According to the procedure manual you should not have to split the tractor to replace the main bearings.
As per the IH service procedure manual, Operation number 4-146-D.
826 Tractor Diesel engine.
CONNECTING ROD AND MAIN BEARINGS
- Replace
1. Drain engine oil.
2. Remove:
o Oil pan.
o Rod caps and bearings.
o Main caps and bearings.
3. Check crankshaft to GSS-1377 for specifications.
4. Install new bearings and check with plastigage.
5. Reassemble.
Flat rate time is 8.8 hours.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
