Posted by Janicholson on December 19, 2010 at 20:22:33 from (67.72.98.45):
In Reply to: Pump fuel posted by Bud Kaiser on December 19, 2010 at 07:36:15:
Slow running engines cannot use either advanced timing or as much high compression as 6000 rpm car engines. The flame front travels at a speed that can cause spark knock easily. With good gasket placement to avoid hot ignition points, a cold spark plug, and 101 LL av gas, I imagine an 8.5 or 9:1 CR would be doable for pulling only. Just a guess, as reality trumps theory. A three main bearing 4 cyl non dynamically balanced assembly will not live at high enough Rs to do 10:1 (opinion) Jim
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
