Dean, Im unfamiliar with that Hitachi alternator, not sure if it requires initial external excitation like the GM 10SI family or not?????? If so, see below:
On the GM I prefer the current limiting (a bit of a safety factor) of a 10 to 47 ohm 5 watt resistor instead of a diode. (5 watts isnt required but has bigger tougher easier to wire leads) It can BOTH limit current PLUS prevent ignition backfeed if required such as on the GM 10 SI family of alternators (again unsure on the Hitachi)
Another option instead of a diode or resistor is the use of a small incandescent "idiot light" which serves THREE purposes,,,,,Gives you "some" indication of charge (on when not charging, off when charging),,,,,,,,,,Excites the alternator if required,,,,,,,Provides some degree of current limiting protection.
As far as Polarity on the diode, for it to work, for Neg ground its cathode must be on the alternator side NOT from the ignition
Bob has ya well covered as far as size and a neat picture, if you use a resistor or idiot light instead, it simply replaces the diode
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
