Posted by Yooper Farmall on December 22, 2010 at 06:57:00 from (141.210.112.16):
I am in the process of converting my H over to 12volts and had some questions about the lights. I understand I need to replace the 6 volt lights or bulbs. I put in a #1156 12 volt bulb for testing, it works but is intended to be a signal/back up light so probably isn’t bright enough for a headlight. Does anyone know what bulb is typically used in the conversion? Is there an enclosed lens, bulb, reflector pan light that will fit right in? My reflector pan is pretty dull and corroded, I doubt it will do much reflecting.
Also, I saw a picture on the front of an OEM magazine that showed a light bar mounted to the front of a Farmall, were these intended to be mounted on either the steering pedestal or the grill or was someone just getting creative?
Ok, as long as you are still reading, I thought it might be save to throw in another 6 volt/ 12 volt conversion question, as others have stated in the past the 1970’s GM 55amp alternator just doesn’t fit under the hood. Luckily I think I can return it, but I need to come up with a smaller alternator option, suggestions?
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
