Re: How to lock a fast hitch into place???
Posted by Wardner on December 24, 2010 at 01:16:07 from (4.154.249.0):
In Reply to: How to lock a fast hitch into place??? posted by Matt (NEIA) on December 23, 2010 at 23:31:02:
The 460 hitch has cast collars on the lift links that can be locked with a 1/2" square head set screw. They eliminates float. The Fast Hitch sockets have 3/4" pins that can be pulled to allow the socket to rotate up. I think both of these features were meant for ground engaging tools such as plows and harrows. May be helpful for a rear blade under some conditions.
The anti-sway bar also has a removable pin to allow sideways movement.
When you use the word "lock" referring to a Fast Hitch, I think about the 300-400 draft position cylinder. It can be removed (or not) and the front end of the bail can be locked up with a pin.
There may be other "locks". An operator's manual would help you set up your hitch the way you want it.
There are also socket latches but I am assuming you are not referring to those.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
