Posted by Rich_WI on December 28, 2010 at 00:10:17 from (71.98.24.189):
My job this week is to change the milky hy-tran in my 460. Im hitting a few problems. First off, I pulled the huge plug under the axle but I only got 5-6 gallons out, does that sound right? I thought I was going to get 10 or 15. I just checked the side check plug a week or so ago and it was only 1/2 inch down so I know it was full. I thought that plug would empty the whole thing.
Then I saw another plug about half way between the huge drain plug and engine oil pan, pointing toward the front of the tractor. I pulled that one and only got another gallon or so. Does that sound about right?
Last, I saw one more plug just behind the engine oil pan. Its a plug in a small plate thats maybe 4 inches by 7 inches with IIRC 6 or 8 bolts that hold it on the cast iron. Well I tried to take out that plug and stripped the head off. Whats under that plate? Im thinking I should pull the plate off and get out the plug while the $100 of oil is still in the sealed buckets instead of the tractor. I dont want to tear into that plate though if there is anything that I can mess up under the plate. Im kinda on a time schedule and want to finish this up on Wednesday if I can because the weather is due to turn here in Wisconsin after that.
I looked in the very back of the tractor by the PTO to see if there was a drain plug there but didnt see anything, am I missing anything or is there no drain back there? I want to get as much of the milky oil out as I reasonably can because I cant afford to do this again any time soon.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
