Posted by redblood on December 29, 2010 at 07:50:31 from (69.97.230.95):
I have a belly mower on my A, I have rebuilt the governer input w new bushing and lever, new upper lever inside, new spring, new roller bearing and spacer. But can not get the rpm to the rated speed. Even with the top screw removed.
I can only get 520 rpm on my pto, at the center of it. With no load.
My rpm meter has a cone which I stick on the end of the pto. Should I be measuring on the od of the pto?
I would like to get a little more rpm to speed up the deck a bit.
Help? I have had this governer off and on the engine, probably 5 times, apart back together. The hand control is maxing out against the housing inside.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
