For what it's worth, when I recored my F-20, I used 5/6" copper heavy wall tubing and soldered it in. You have to clean the the line and tank REALLY well before you start.
works fine, and doesn't leak.
I did have to use the acetylene welding tip to get enough heat though. you need to be real careful, and heat the tubing......too much concentrated heat is no good for the cast. I tinned it before I put it in, then heated the brake like, and pulled the solder in. I did the tank side first, then turned it over and did the rad side last, to let the solder work down and around.
It would be interesting to use JB Weld for this job. I have had excellent success with JB weld for repairing the oil cups on the air cleaner and similar sheet steel parts.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
