Likely leaking at the oring or seal where pump attaches to engine. I would remove the pump, then find out what you need. My C had a oring leaking (old and worn). I had a hard time locating an oring that was correct size. It seemed to be an odd ball size, but finally located at an older dealer. He had to go through some serious checking to figure out correct part number. Maybe you will be lucky, and it will be the common seal that is easy to get. They used two different pumps....I believe Pesco, and Thompson if memory serves correctly. Cannot recall which I had. The good news is that it lasted 60 years so I doubt I will have to do it again
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
