Posted by Troy Schubert on January 03, 2011 at 13:48:32 from (63.166.241.80):
The right side roller bearing cup in the differential has some major divots/damage. I've visually inspected the other bearings in the differential and they appear OK. I've convinced myself that I need to replace the bearing cup at a minimum.
Looking for any advice:
1/ should I replace the right side roller bearing AND the cup even though the bearing looks OK?
2/ Only place I can find to order the bearing cup is www.messicks.com. P/N 86500721 for $63.81. Any other ideas where I can order this Timken bearing? The original Timken number for the whole bearing is 3044002R91 and it cross references to a 482/472. All my searching has not produced any US distributor where I can order it.
Best I can tell from the Timken failure analysis pics is that the bearing was exposed to water and corroded. It makes sense because I do have a leak between the differential cage and diff housing, but doesn't make sense because the other bearings appear OK.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
