6 quarts is often not enough to raise these loaders all the way, so they have auxiliary reservoirs.
If the loader uses the tops of the cylinders for auxiliary reservoirs, the cap should NOT be vented.
Problem is, you don't know what you're looking at and we can't see what you're looking at, so there's no way we can be 100% sure of what you have.
There should be hoses running from the fill pipe on your belly pump, up to the tops of the hydraulic cylinders, if they are being used for auxiliary reservoirs.
If there are no hoses running from the fill pipe on your belly pump, then it does not have an auxiliary reservoir. 6 quarts would be all you need in this case.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
