Properly fitted connecting rods/bearings will ALWAYS slide from side-to-side within the limits of the journal width. There HAS to be enough play (typically in the .0175" to .0035" range) for the bearing to "float" on a film of oil. Much tighter and the bearing will lack lube, overheat, and seize.
If I were to worry about anything overtightening the bolts would have done I'd worry about stretching the bolts and weakening them.
Typically, if the bolts are replaced the "big end" of the rod should be checked by a machine shop with a rod machine.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
