8 volt batteries have been used on 6 volt systems for as long as I can remember. They are usually put on when the tractor became hard starting. But the lights and all work just fine. I would look into getting an 8 volt regulator because it just maintains the battery better. There is a way of you adjusting it your self on the old mechanical regulators and that is to bend hook up a VOM or DVM and hook it appropriately across the battery. Pull the cover off the regulator ans you will see two coils. One is the regulator come in relay and the other is the regulator. Start the engine and runt the rpm up till you see the voltage increase on your meter to show a voltage above the standard battery voltage. Increase the rpm a little more to make sure the voltage is stable and doesn't increase anymore. I have a tool I made for doing this by taking a screw driver and cutting the tip off and cutting a straight slot in the end so I can place it on the side of the spring tab. Place the tool in place on the tab and carefully by twisting the screw driver and bending the tab down tightening the spring tension. You should see an increase in voltage. Just adjust it until you have a voltage of about 8.25 to 8.5 volts. You don't want to go much over that or you will start burning bulbs. When you get it whee you want it, shut everything off and screw the cover back on the regulator. If it's a solid state regulator I got no idea. lol He** what do you expect form an old man. I guess old info. LarryT
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
