Posted by Dave H (MI) on January 10, 2011 at 07:07:43 from (66.87.6.137):
In Reply to: Farmall A carberator posted by Andrew Anderson on January 10, 2011 at 02:30:25:
When you rebuilt that carb did you soak it overnight in clean carb cleaner?
Did you check your float to see if it leaked by immersing in hot water and looking for bubbles?
Did you buy a quality kit and install it or just tear it down and clean it?
You have a problem with your float and/or needle and seat. They are not working together to shut off the gas as needed. I would start by disassembling and cleaning very well. Check the float and replace if necessary. When you get your carb clean use some rubber gas line with in line filter for a while to make sure that you are not being chased in circles by crud from the tank...BTDT. You can reinstall the old line after you get things a-runnin right.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
