Charlie pretty much covered it. It is an underdrive unit. Direct drive is lever ahead as would give same gear ratios you have with out a TA. DD is driven through a 7 inch dry clutch very similar to any dry clutch and low range TA is a reduction through a planetery gear set. It utilizes a one way clutch mounted at rear of planet carrier commonly know as the ramp and roller that keeps carrier from rotating backwards. When the one way clutch fails it allows the carrier to rotate backwards, input going forward and output shaft stand still there fore tractor does not move. What usually happens is the rollers in the one way form a groove in ramp and therefore they cannot move out to lock (wedge) onto the carrier. Heavy oils in rear end also cause these rollers to stick much more so than lighter hy-transmission lubes. The tractor will free wheel when pulling ta lever back and like said is not a good thing to do at high rate of speed. Normal usage with free wheeling for a few feet at lower gears does no harm. Being a mechanic, of course we like to throw all the blame one can onto an operator if something fails, but truth is, they are basically wear items and they fail with use. That is what is on the tractor for though so use it and don't abuse it at they are fine. TLC goes farther than anything else on any piece of equipment. I have seen owners change fluids etc religiously and beat the heck out of their machines and have all kinds of breakdowns, and vise versa, seen operators rarely change fluids but handle everthing with kid gloves and they last forever. There is always a balance point.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
