Re: Starting a Cub in the cold
Posted by ericlb on January 15, 2011 at 18:57:03 from (12.189.32.54):
In Reply to: Starting a Cub in the cold posted by ellson on January 15, 2011 at 18:36:45:
just got thru with that problem with my '49, what i found is partialy it may be ih lol, [grandpa had a M that was the same way while the C would start right up] but seriously your tune up has to be spot on for cold start 6v, the mag points need to be fresh and proper gap, not close, but proper gap, plugs must be fresh and not fouled, solid core plug wires must be in good shape cap rotor ect, carb must be properly set, if it runs well when its warm out its fine dont play with the tweek-um screws on the carb if it runs good when its warm out, battery cable conections must be clean bright and tight, check all that and ill bet she'll start you'll have to play with the choke to figure out your tractors "sweet spot" for cold start every tractor is different
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
