If I recall correctly you just got this tractor from a scrap yard. Did the hydraulics work before you started to change oil and filter? Does the PTO start up? If not the problem may be the PTO input shaft splines in the clutch pressure plate. The PTO drive shaft also drives both hydraulic pumps. Usually they will make some noise but that goes away if it has been run long enough with the splines worn out. Another possibility is the rivets sheared off the back of the pressure plate cover. When that happens there usually is no noise. You can inspect this by removing the cover under the clutch and looking up between the clutch release levers on the pressure plate.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
