Posted by wayne in mn on January 19, 2011 at 19:31:11 from (24.179.171.87):
In Reply to: Super C Stalls posted by Scott Bardman on January 19, 2011 at 18:20:18:
With the engine cold, pull the coil wire out of the distributor cap & hold about 1/4" from a metal surface. Turn the switch on and crank the engine. You should see a bright blue spark. If it is weak & yellowish you have an ignition problem. Repeat when the engine stalls to see if there is a difference. 3 things are needed to run an engine; strong timed spark, burnable fuel mixture, and decent compression. When the engine quits or won't start, look for the missing item.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
