I would just use the IH 400 hydraulic screen provided the Liftall reservoir can maintain the partial vacuum caused by the pump. Of course, it must be capable otherwise it would leak oil
Without going outside and trying to find a 400 reservoir in two feet of snow, I am guessing you will have to weld a pipe fitting to the steel exterior of the brass screened filter. I am sure that a homemade plate where the pipe manifold attaches to reservoir is in your plans. Or maybe you could just draw from the plate that would be threaded for a 1" NPT and forget modifying the filter.
Don't you love it when you can recycle an old IH part and put it to a new unintended use.
I suppose the F-400 reservoir is rotated 180 due to clearance problems with steering column. If you had a W-400 reservoir, that would not be necessary as there is a recess for the large steering gear housing.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
