Dennis, do you have a compression gage and air compressor? And the engine is stuck, correct? You could unscrew the gage, screw the hose into a spark plug hole one at a time, then plumb it up to blow some compressed air down each cylinder, before you take off the head. BUT take the rockers off FIRST to close all the valves.
If you put a tablespoon of oil in the hole first it will help seal the blowby at the rings, and it will help the stuck rings, too. Put a valve in the hose, so you can control the air. Make SURE the transmission is in neutral in case the engine does break free. It probably won't.
Now, listen to where you here air leaking out. Some should come out through the rings, except a really stuck cylinder. Some might come out the valves if they don't seat well. Listen at the exhaust and then the carb. If you've only got modest leakage, look in the radiator and see it you have bubbles. Might help you narrow down the problem to one cylinder. Best Regards, Charlie
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
