Posted by D Slater on January 26, 2011 at 05:26:17 from (184.15.23.120):
In Reply to: locked up H posted by jbuckshot on January 25, 2011 at 18:28:27:
If the tractor will roll okay when shifter is out of gear and clutch engaged, its not in two gears. Something is keeping the transmission input shaft, lower transmission shaft or belley pump from turning. If you don't find any ice, a roller from the main shaft pilot bearing can come out and wedge between the constant mesh gears. With the clutch pedal blocked down, trans out of gear put the pto in gear and see if it can be turned backwards or back and forth to dislodge anything stuck in the gears. Would remove the front trans drain plug to make sure no ice under the constant mesh gear first. Ice most times blocks the bull gears also if its there though, then tractor wouldn't roll. Maybe drop the inspection cover under the hydraulic pump drive shaft and make sure pump shaft turns also. If easy stuff fails remove the belt pulley gear box or cover and look for the problem. This is just guess work without inspecting what you have.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
