DW, go to caseih.com parts and search on model 2400 and you will find the Fwd-Rev under drive train. My brother has a 684 with T/A which is very similar to the Fwd-Rev as it was activated by lever on left of steering column. The only difference T/A reduces ground speed by 20% giving a shift on the go Hi/Lo in every gear turning the 8 speed into 16 speed + 8 rev. I looked at Fwd-Rev parts diagram and it installs in the same location as T/A but has two hydraulic clutch packs and an extra counter shaft to provide the rev. It is very difficult to tell if it is the clutch or Fwd-Rev. Usually if you put trans in 1st gear Lo range and tractor is on the level, even if the clutch is bad the tractor will move unless the springs are shot on pressure plate. There is an inspection plate on bottom of clutch housing where you can see a little of clutch operation. Does tractor change attempted direction if you change the Fwd-Rev lever?
If you email me at clarabrownlee@rogers.com, I will scan hydraulic test procedure for 684 T/A which should be very similar to 2410B Fwd-Rev.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
